I'm using the Marlin firmware (1.1.0-RC7 - 31 July 2016) for a 3d printer. Currently the printing is not perfect due to slight inaccuracies in movements along the x and y axis. I'm trying to change the feedrate for speed along the xy axis whilst the printer is in operation to make sure the printer stops on time and prints accurately.
I have some code for controlling the feedrate but the problem is that I'm not sure where I am supposed make these adjustments. In the configuration.h file I see this code: (lines 742 and 753 )
/*line 742*/ #define HOMING_FEEDRATE_XY (50*60)
/*line 753*/ #define DEFAULT_MAX_FEEDRATE {300, 300, 5, 25} // (mm/sec)
I'm probably misunderstanding something but it seems like this sets the feedrate to a default value which is the same as the maximum.
If the feedrate changes during printing I'm guessing it would be done in Marlin_main.cpp but I'm not sure which part it actually changes. Can someone point me in the right direction here?
