I want to skeletize the surface mesh. For that I need to export .STL from Solidworks and then convert that into .OFF file to be able to use it in CGAL library for skeletonzation. How can I do this?
2$\begingroup$ Look at MeshLab it imports and exports both .stl and .off I have not used .off so not familiar on how well MeshLab handles them. MeshLab is open source. $\endgroup$ – spicetraders Nov 21 '16 at 17:05
If you can handle a single intermediate step, you may find that OpenSCAD will perform as required. As a test, I created a cube 10 x 20 x 5 within OpenSCAD. I kept the model simple, hoping the code generated would be short.
The results:
OFF
8 12 0
0 0 5
10 0 5
10 20 5
0 20 0
0 0 0
10 0 0
10 20 0
0 20 5
3 4 5 1
3 0 4 1
3 0 7 4
3 4 7 3
3 0 1 2
3 7 0 2
3 3 6 4
3 4 6 5
3 5 6 2
3 1 5 2
3 7 2 3
3 3 2 6
In your example, it would be necessary to use the import_stl feature of OpenSCAD, then render the model. Once rendered, use File, Export, Export as OFF to create the file you need.
I cannot provide certainty of the exported code, however, as I am not familiar with the format you seek.
I would suggest using Meshlab. You can convert from .stl
to .off
and you can try other operations for quick results too, instead of diving to code for mesh manipulation.
There is the Free online tool to convert STL to OFF within second: https://cadcook.com/stl-off/
I used it for stl conversations..
