I've just tried to make some small labels with embossed lettering. Base is 1.5 mm, with letters and a perimeter protruding by another 1 mm. After printing, I realised that Cura is not giving me a top layer, all I get is an inner and outer wall for the perimeter and the lettering:
The base is OK, with 4 layers, but there is no infill at the top. Presumably there is a setting that I've missed (I can appreciate that maybe this is a detail to the slicing which is model dependant). Layers are 0.2 mm, top and bottom set to 4 layers.
I had walls set to 1.6 mm, (4 layers) and the wall features here are 1 mm (i.e. 2.5x the nozzle). The features are solid so far as I know, not drawn as a hollow.
I found a relevant bug for Cura: https://github.com/Ultimaker/Cura/issues/1303 (and I also understand a workaround now, just need to write up an answer).
