I'm considering using CAT6 cables to connect my printer's extruder assembly to the control board. They seem like an elegant solution, but I've read conflicting opinions online on whether or not this would be feasible.
I would like to know if CAT6 cables can handle the required current, whether I should be worried about electromagnetic interference or other problems, and how I should pair up the wires. Cable length would be 30cm max.
Here are the relevant parts:
- E3D heater cartridge (2 wires)
- E3D thermistor cartridge (2 wires)
- 30mm hotend fan (2 wires)
- Z-axis auto-leveling probe (3 wires)
- NEMA 17 extruder motor (4 wires)
- 50mm part cooling fan (2 wires)
[cable A] I imagine I would use one CAT6 cable for parts 1-4, which form a logical unit (and in the future I might combine them into a removable module). I've been given to understand that power for the fan can be spliced from the z-probe or heater cartridge, so 8 wires should be enough.
[cable B] I would use a second CAT6 cable for parts 5 and 6. There will be two spare wires, so I could potentially double the bandwidth for the motor.
