19
I want to create parts for a 3D printer using OpenSCAD. Having some STL files from the vendor, but nothing else (no technical drawing, no CAD files).
Does anybody knows a free tool, that allows me to
  • measure distances between 2 selected vertices,
  • measure distances between a selected vertex and a plane defined by 3 vertices,
  • measure the radio of a circle defined by 3 selected vertices?
I very much like the way Blender allows to work with meshes, especially select vertices or planes, but unfortunately haven't found a way to measure with Blender.
    $\begingroup$ As far as I know, there is no real size information saved in .stl files, only relative positions of points in a generic unit measure. When opening an STL-file, you will have to specify how long one "unit" is. Most editors probably use millimeters or inches by default, but mixing them up will yield results such as this. Just thought you should know. :) $\endgroup$ Jan 2, 2017 at 11:21
  • $\begingroup$ At thingiverse, for example, you often find only STL files that print in the right size, so the values in the files seem to be mm. $\endgroup$
    – Thomas S.
    Jan 2, 2017 at 14:36
    $\begingroup$ There is also a Blender community here on the Stack Exchange network if you have more general questions about Blender. $\endgroup$
    – tbm0115
    Jan 3, 2017 at 6:08
7 Answers 7
18
I suggest Blender. It's not the simplest of tools but it is free and learning it will improve your 3D printing skills. :-) (I write this answer also for future viewers of this question so I start basic).
Another answer can be found here, How do I measure a distance between two points?
  1. Import your STL file.
  2. Press the Home key to view everything.
  3. Select the model by clicking on it with your left mouse button. (Blender changed to left-click-select as of version 2.80)
  4. Hit tab to enter edit-mode.
  5. Press N (or use View | Properties) until the Properties panel shows up.
  6. Select the "Length" checkbox in the "Edge Info" section of the Properties panel (see image below).
  7. Select "Edge Select" mode (see image below)
  8. Select the edge to measure by clicking on it with your right mouse button.
Edge length
Screenshot of toolbar
If you need to measure the distance between to vertices with no edge. Create the edge by selecting them and pressing F. If you need to measure the distance between a vertex and any other point, select it and press E to extrude.
As @Gunslinger suggested, I would also recommend Blender for these tasks.
Blender comes with the Add-on "MeasureIt", which has to be activated manually in Edit ► Preferences ► Add-ons ► Official/Community ► search for MeasureIt, check the checkbox:
Blender preferences
Import your STL file via File ► Import ► STL ► ...
Select your object and hit TAB to enter Edit Mode and then follow the tips in this screenshot:
Screenshot
Use Meshy "...a WebGL-based tool that does measurements and simple transformations on STL and OBJ files.": https://0x00019913.github.io/meshy/
If you're running Windows, MS 3D Builder has a measuring tool and may already be installed on your machine.
    $\begingroup$ I'm having pretty good measurement success with 3D Builder $\endgroup$
    – eephillip
    Aug 13, 2017 at 14:28
Meshmixer has various measuring tools for STLs as well
That is great. You can also do the 3D model measurements using SelfCAD software. I can confidently recommend to all users because it is suitable for both 3D artists and beginners. The software has a built-in Measurement Tool that allows users to accurately measure the size of 3D models. The tool can be used to measure the length, width, height, and angle of a 3D model. To use the Measurement Tool, users simply select the part of the model that they want to measure and then move the pointer to the desired measurement point. The Measurement Tool will then display the measurements in the software’s measurement panel. Check this video on how to do the measurements of 3D models using SelfCAD
-1
I recommend Ultimaker Cura 4.3 for dimensioning.
You can access it here.
Screenshot of Cura
As can be seen, detailed measurements can be made over the specified coordinates.
Screenshot of Print Size Wizard
However, you can make an accurate dimensioning by using the Render program. I recommend doing this before working on the STL file.
I wish you good work.
    $\begingroup$ As it’s currently written, your answer is unclear. Please edit to add additional details that will help others understand how this addresses the question asked. You can find more information on how to write good answers in the help center. $\endgroup$
    – Community Bot
    Apr 24, 2023 at 13:07
    $\begingroup$ Why referring to an old version, 5.3 is now the current version! Please explain this, e.g. because the feature isn't available in the new version or something like that... $\endgroup$
    Apr 24, 2023 at 20:36
  • $\begingroup$ I worked a lot with this version. Although the version difference is not much, I wanted to recommend it because I am satisfied with the version I use. Upgrades may consume more memory on your computer. This version, which works efficiently, will be sufficient for the work to be done. $\endgroup$ Apr 25, 2023 at 6:00
  • $\begingroup$ Why reference an version at all then? $\endgroup$
    May 8, 2023 at 13:37
