I want to 3D-print some parts that will be later joined together along a seam. When modeling these separate parts, what are some methods that work well with 3D-printed pieces? For example, if I were doing wood working, I might choose dowel and pin joints or mortise and tenon joints or glue overlapping pieces. What methods translate well into use with 3D-printed plastics? How does the answer change depending on the orientation of the joint along the printing direction?
$\begingroup$ See: What is the best way to connect 3D printed parts? $\endgroup$– kenorbJan 19, 2016 at 19:52
1 Answer
One of my favorite techniques is to join pieces with screws, and include a tapered feature that helps align the parts. A single screw can give a very strong joint, that is well-aligned and won't twist. Another advantage is that such joints can be printed in any orientation, since the tapered feature can be designed with 45 degree angles.
Here is a cross-section example of such a joint:
