I'm trying to gear down a servo even further. I notice that the majority of the gears are made of nylon, and I want to create new gears that come close to the resolution and strength of the existing gears. I have a Replicator 2, but the resolution does not seem to come close to what I need. Any suggestions on how I can create nylon or other hard material parts that might work?
  • $\begingroup$ perhaps you mean nylon? $\endgroup$ – fred_dot_u Jan 13 '17 at 18:22
  • $\begingroup$ oops, yes, corrected $\endgroup$ – user379468 Jan 13 '17 at 18:27
  • $\begingroup$ Fred seems to have you covered. That said way too much work to get a replacement part.. Just buy mass made after market parts. I am sure you can get them on ebay for cheap for such a common printer. $\endgroup$ – StarWind0 Jan 13 '17 at 23:02
  • $\begingroup$ Just because you mentioned how to create metal parts. Look up Lost PLA casting. $\endgroup$ – StarWind0 Jan 13 '17 at 23:04
  • $\begingroup$ His term was "hard material" not hard metal, but any form of casting would require to have a decent resolution in the original part. One can now purchase also wax casting filament if burning out PLA isn't practical for the casting operation. $\endgroup$ – fred_dot_u Jan 13 '17 at 23:56
Proceeding with the expectation that you mean nylon rather than vinyl, there are a few options open for you. What resolution are you seeking? Layer thickness of 0.100 mm is quite good, allowing for ten layers per mm of part thickness, with infill adjusted as required.
If you've already determined that your printer will not print at the resolution required for your gear design, you would perhaps purchase a higher resolution printer. Of course, that may be an expense you would like to avoid.
If your parts count is small, you could consider to print samples of the parts to confirm fit, but not worry about strength and then use an online service to have them printed via SLS method.
Selective Laser Sintering places nylon powder on the work surface, then selectively melts the powder into a solid. Each layer when completed is covered with another layer of powder and fused to the previous portion (or not) until the part is complete.
Because the un-fused powder provides support, there is no requirement for the model to have supplemental support structures. There is a requirement/objective that the part have "drain holes" in areas which might otherwise be solid. Any surface that entraps powder is charged to the purchaser as if the space within is included in the part.
An example would be a cube that can be printed as six square faces only. The cube wall thickness can be specified and if a drain hole is incorporated, the cost would be the volume of the walls only. No drain hole would mean the cube would be charged for the entire volume.
For gears, which are typically low profile/flat items, that's a minor consideration.
The same concept applies to SLA printing, which uses a laser in a vat of resin. If the model is a solid with no drain holes, the interior will retain the resin. It is possible that the interior can be cured with strong UV light and/or sunlight, but opaque resins would not accept this work-around, nor would it reduce the cost involved. Also note that SLA printed items would lack the necessary strength.
If farming out your parts is the direction you intend to travel, ensure the dimension stability reference in the vendor you use. Nylon sintered parts will shrink a known amount during the fusing process. The vendor should provide the appropriate reference, or the vendor should confirm that he adjusts the model appropriately for shrinkage.
I have one very tiny part constructed from SLS nylon and it's amazingly strong for such a thin wall. Nylon wears well too.
  • $\begingroup$ They likely would only need to buy a e3d hotend or the like to increase their resolution. but 0.1mm is great for any hobbyist level printer. Though SLA / powder prints are a bit overkill when he just needs replacement parts? we also need to know more about his exact needs and budget. $\endgroup$ – StarWind0 Jan 13 '17 at 22:59
    $\begingroup$ @StarWind0, I'd like to know more about user379468's requirements with respect to the resolution of the model. Your suggestion of a different hot end would be practical or a replacement smaller diameter nozzle. A smaller diameter nozzle has its own complications, but may be the right answer overall. Regarding the overkill aspect, he may have requirements not met by off-the-shelf stuff. That's one aspect I enjoy about my printer, the ability to create exactly what I need, or at the very least, take a stab at it! $\endgroup$ – fred_dot_u Jan 13 '17 at 23:59
If changing the nozzle to a smaller diameter is a viable alternative for your printer, then that may give a major increase in your X-Y-resolution.
You can think of it like drawing with a pencil vs. a thick crayon: a fine tip allows for fine details.
Personally I have done some printing with a 0.25mm nozzle, which was a bit of a challenge to find good slicer settings for, but otherwise went very well, giving much better resolution than my 0.4mm nozzle (nearly twice a good to be exact).
    $\begingroup$ This approach is true up to the point where the mechanical quality of the printer is less than the nozzle size, after which it's not getting you anything if your printer won't put the nozzle exactly where it's supposed to be. My cheesy Delta is somewhat past this point with a 0.3, I suspect. A Cartesian printer with quality parts should be able to go quite a ways in this direction. $\endgroup$ – Ecnerwal Aug 25 '17 at 21:39
