I'm creating a reverse Bowden setup to guide my filament from spool to extruder, through a path which contains two couplers in the middle as follows:
[spool] --- |#= --- =#| --- [extruder]
So I have to connect a tube to the back of a coupler (---=#|) and not just to the front (---|#=). That's the end that contains the screw thread, and it's not designed to take a tube. I can't manage to make it a smooth transition. When I try to push my 1.75 mm filament through, it will often get stuck there. After it's through, the extruder seems to have no problem with it anymore.
Is there a trick to making this a smooth transition?
The solution might be to countersink the opening at the threaded portion within the tube. There are various angles available for countersinks, although the more common angles are 82 degrees and 90 degrees.
Drive the countersink to the point where the wall thickness is zero, unlike the drawing below showing some material outside the beveled area.
For your purposes, you'd want the steepest angle possible, the 60 degree tool. If you decided to purchase a countersink, pick a diameter slightly larger than the outside diameter of the wall thickness of the coupler. You could use a countersink of the same diameter as the outside diameter of the threads.
Center drills are available with 60 degree angles as well: Amazon specific item enter image description here
The second smallest center drill listed here has a 1.5 mm center point with a 4 mm drill point. If your coupling is larger than 4 mm, the next size up will not work as well, as the center point is 2.5 mm. You'd have to resort to a countersink only.
If you are near a machine shop or have a friend with a mill or even a decent drill press, those resources may be able to perform the countersink for a minimal (or possibly zero) fee.
I have a mini-mill and a collection of countersinks as well as center drills. I found my bag of unused couplers. They are for 5 mm tubing and were flat on the threaded end. This is the result after a quick trip to the mill. It appears in the close up that I could have driven the center drill deeper into the fitting, and also cleaned off the swarf a bit as well.
Chamfered inner hole backside of the pneumatic coupler
  • $\begingroup$ That makes sense. :-) Thanks for the great answer. As it happens, I am finding some 60 degree center drill bits with 2mm tip on Amazon, so those should do the trick. $\endgroup$
    – mhelvens
    Jan 15, 2017 at 23:11
An alternative to chamfering the connector is buying a different type of connectors with a larger bore hole all the way through the connector and let the tube pass all the way through. These are used in my similar spool to extruder setup (reversed Bowden setup in OP's terminology).
Large hole pneumatic tube connector
