I want to print a text inside a box. I mean the text should be cut out (see through). Example: enter image description here
As you can see the parts in "o" and "e" cant float.. it needs some kind of a support. Also the top triangle in the M can't be printed without a support. Here is something I found, I think this is what I need:
Can you recommend me a font or some app to make these fonts printable the way I need it?
The software I use is Simplify3D and all the free ones like cura.
I did a quick search using The Google with the terms "stencil font." There were too many results to list here and the first link I clicked on provided some seriously ugly fonts. Stencil fonts by definition will result in supported center pieces. Windows has a native font named, surprisingly enough, Stencil which does the same, but it's not quite as imaginative as the ones found using The Google.
Here's an example from Font Squirell:
Octin Prison
Octin Prison Font
How about something a bit more bizarre from the same location:
VanBerger Font
VanBerger
| improve this answer | |
