We have stepper motors with these specs:
- 1200 mA
- 4 V
- 3.2 kg • cm
Are these enough for building a Prusa i3 3D printer?
(I live in Turkey and these are the specs of the NEMA 17 they sell in here)
Sign up to join this communityWe have stepper motors with these specs:
Awful answer, I know, but it depends... on where you are going to employ them:
If they are for use in translating movement of the axes, then the weights of:
will all come into play - amongst many other things.
With a torque of just 32 N • cm1, they seem, at first glance, to be a little underpowered - a torque of 44 N • cm (4.5 kg·cm) is the recommended minimum. Also, the current, of 1.2 A, seems to be a tad on the low side, 1.5 - 1.8 A is recommended.
There are some great resources on the RepRapWiki. See:
The minimum (recommended) specifications, for a Nema 17 stepper motor, are:
- 1.5 A to 1.8 A current per phase
- 1 to 4 V
- 3 to 8 mH inductance per phase
- 44 N·cm (62 oz·in, 4.5 kg·cm) or more holding torque
- 1.8° or 0.9° per step (200/400 steps/rev respectively)
You may be able to get yours to work, but is it worth the hassle, just to save a few quid? Best to get the recommended, and most popular steppers, which are:
Obviously, you don't have to use one of these three motors - other stepper motors can be used. On the Nema 17 Stepper motor link, above, there is a table of a number of stepper motors, of various makes and models, that have been proven to work.
Motors, a thread on the RepRap forums - specifically for the Prusa Mendel v2, so not entirely related to the i3, as the steppers for the z-axis are less than those for the x and y axes, but it is a good informative read nevertheless.
1 I assume that you actually mean either 32 N • cm, or 3.2 kg • cm.
