I have seen a few guides mentioning w/t ratio but I can't find anything which defines it.
I am using Simplify3D with a Wanhao i3.
  • $\begingroup$ Can you put the question into a context? What is the ratio referring to? A printer? Filament? Software? Presumably, you are referring to guides about Simplify 3D? Can you edit your question and provide links to, and quotes from, these guides, showing where w/t is used? $\endgroup$
    Feb 8 '17 at 5:51
It appears to refer to calibration factor called Width over Thickness.
From Calibrate your 3D printer to print parts to fit
Here is the list of necessary variables for this calibration to work,
  • Carve/Extra Decimal Places (float) : change to 5
  • Carve/Edge Width over Height (ratio) : nozzle diameter/layer height
  • Inset/Infill Width over Thickness (ratio) : nozzle diameter/layer height (initially)
  • Dimension/Filament Packing Density (ratio) : needs calibration (equivalent to the reciprocal of the extrusion multiplier in Slic3r)
  • Scale/XY Plane Scale (ratio) : needs calibration
