This is my second 3D model, be forgiving... ;)
I have constructed a 3D model with some bigger solid parts with FreeCAD. After uploading it to shapeways, it turned out to be too expensive to be printed like that.
Googling around, gave me the solution to make it hollow and use a support structure. If you know which exact printer model is doing the print, Slic3r can do the job. But as I want to print with shapeways, I just know the material, and they are doing the slicing. Obviously without creating support structures in solid parts. Hence, this way does not work in my situation.
Searching for an other solution, I found this article, FreeCAD: Perforated Sheets and HoneyComb, describing how to create a honeycomb structure by a little piece of code. I would have to make my part hollow by subtracting a shrunk version of the model and fill it with the honeycomb structure. This sounds feasible to me, but is quiet a certain effort.
Is there an smarter solution to achieve a hollow piece with support structure?
  • $\begingroup$ If they do the slicing then they will sure generate honeycomb (or other) filling anyway. I actually believe generating your own filling like this could mess up the print. Don't they have a setting or option for fillings in the order form? $\endgroup$ Feb 12 '17 at 15:07
  • $\begingroup$ @TomášZato I don't think, they do a filling optimization. Otherwise, I could not believe the high price for the small model. It is about 6x6x2,5 cm, has to big cutouts and should cost nearly 50€. $\endgroup$
    – andreas
    Feb 12 '17 at 18:59
If you want to have a specific infill density, you can design the infill yourself as part of the solid model. (Note I use these two methods to design parts for strength, but it's basically the same thing that you're looking at doing)
I have two methods for doing this as follows (I use Solidworks, but the features exist with most CAD software)
Method 1
Step 1
Design the part for the geometry that you'd like as you usually would. (check the volume of the part)
Step 2
Hollow out your part and set your wall thickness to the desired dimension. In solidworks, you can use the shell command for this. (check the new volume of your part)
Step 3
Create a pattern for the print orientation you want and make the thickness of the pattern set to a variable you can easily change. For example if you want a hex pattern, then create a hex pattern that covers the footprint of your part.
Step 4
Extrude your pattern from the bottom surface to the upper surface. (depending on how complex your part is you may have to iterate between steps 3 and 4 to fill the part completely, but that's half the fun).
Step 5
Close the part off. The Shell feature hollows out a part, and removes most of one flat surface. You just need to go back in and close this surface off again once you're done, generally with a single extrude.(check the volume of your part again)
Step 6
Now you can compare the volumes of your part, this may require you to change the thickness of the hex pattern, and may require several iterations to get an exact density that you want.
This process wont necessarily work for every part you come up with but it's a good start for fairly blocky parts. It's also relatively quick and easy to do.
The second way is as follows
Method 2
Step 1: Create your part as usual and save as a unique file (lets call it "Solid file")
Step 2:
Create hollow the part out and save as a unique file (lets call it "shell file")
Step 3:
Create a new part that is your hex pattern, but instead of modelling the walls that will be in your final part, create the hex voids as a solid. Save this as a separate unique file ( lets call it "Void profile")
Step 4:
Create a new part and import both the "Void Profile" and the "Solid File".
Step 5
Subtract the "Void Profile" from the "Solid File"
Step 6
Import the "Shell file" and merge it with the result of step 5
This process I like a bit more, but it takes longer, creates more files and is a bit messier I think. However it gives you a lot more control over how your voids will work and you can delete sections of the voids if you want different parts to be more solid that others.
If you're using solidworks shell model and you have very tight features sometimes it gives you errors, and you may need to suppress small features and then add them back in after all of this. Just a heads up, it can be a bit of a flaky feature to use sometimes.
Now that you have your 'designed' internal structure don't forget to print at 100% infill, otherwise a slicer program may hollow out your designed infill pattern.
