If I wanted to add my own custom M Codes in Marlin - in which source code file would I do that?
    $\begingroup$ This answer is relevant for Marlin 1.x, but not for Marlin 2.x $\endgroup$
    – K Mmmm
    May 19, 2020 at 17:24
In the file Marlin_main.cpp on line 7131 there is a switch case:
(To turn on line numbers go to File>Preferences and click Display line numbers.)
case 'M': switch (codenum) {
  #if ENABLED(ULTIPANEL)
    case 0: // M0 - Unconditional stop - Wait for user button press on LCD
    case 1: // M1 - Conditional stop - Wait for user button press on LCD
      gcode_M0_M1();
      break;
  #endif // ULTIPANEL
  case 17:
    gcode_M17();
    break;
  etc.....
Adding another case with an unused number such as 5 and then the code you want followed by a break should do the trick. Ex:
case 5:
   doABunchofCoolStuff();
   myservo.write(thebestposition);
   break;
-AC
