In Cura, I can edit my .ini profile settings as needed, for example, when I change filament or models. It's annoying to have to edit the profile on another computer and update it on my Pi just to change the infill, etc. I've searched http://plugins.octoprint.org/ and can't find any plugins that do this.
$\begingroup$ I noticed that your question has not had much activity lately, are you still looking for an answer to this question? How might we be able to close some gaps? $\endgroup$– tbm0115Jul 3, 2016 at 20:24
There is an import function. https://github.com/foosel/OctoPrint/wiki/Plugin:-Cura
Btw. now in Cura 2.1 you'll also need to reimport your .ini.
Regards :)
You can manually edit the .profile by using an SSH terminal program (e.g putty) to log into your Pi
Then cd ./octoprint/slicingProfiles
ls to see folders (on mine I see cura) cd cura ls to see profile files e.g fred.profile sudo nano fred.profile
move down to where you can see the slicing parameters and edit away
$\begingroup$ This doesn't answer the question, which asks for a way to edit the profiles within octoprint. Editing them through SSH (from another computer) is exactly what the question seeks to avoid. $\endgroup$ Jul 30, 2016 at 7:15
$\begingroup$ IDK, this seems like a pretty decent answer given you most likely access octoprint from a browser on another computer, so to putty in, is only another window, no editing of files and then having to FTP them over. Just edit in place. $\endgroup$ Feb 1, 2019 at 16:32
