I am about to purchase a TronXY X3 or P802; but, my PC is running Windows 10.
The spec sheet for the printers does not list anything above Windows 7. Is anyone using either of these printers with Windows 10?
Since the printer supports using an SD card, you don't need to connect it directly to a PC. Serial over USB has been broken in the past in various Win10 builds, I've not tried it recently and I've not tried connecting my A8 to my PC recently either.
If you need to use USB, and can't make it work with Windows, there is always the option of using a Raspberry Pi single-board computer (which you can then connect to by VNC from your PC). Depending on the software you want to use, this might resolve any remaining issues you have.
Typically, (hobbyist level, FDM) 3D printers do not require dedicated drivers. They simply show up as a serial port (COMx), and you just need drivers for the USB-to-Serial chip used in the printer's electronics. This is usually an FTDI device, an AtMega32u or CH340. Drivers for those are readily available (and are usually even downloaded automatically through windows update).
The P802 appears to use a variant of the Melzi board, with an ATmega1284p (the less-powerful cousin of the 2560 found in most printers) as the main processor and it claims to have an (FTDI) FT232RL serial converter (I could not find any information on the X3). You should be aware of this, as there are many fake FTDI chips on the market, and FTDI has been known to "patch" their drivers to break the clones. However, this problem is not specific to Windows 10. You can pretty much count on any 3D printer that works in Windows 7 working in Windows 10.
Here's a tidbit that might be helpful to people.
The TronXY X1 boots at 115200 baud (you can change it in Configuration, but each power on it will reset to 115200).
In Repetier Printer Settings I set the baud rate to match at 115200.
My PC automatically recognized the USB device as USB-SERIAL CH340(COM5
But...
I had to go into my PC's Devices and Printers, right-click the USB-SERIAL icon, go into Properties->Hardware->Port Settings: change Bits per Second from 9600 to 115200.
All good now.
For Windows 10 driver, go directly to the Microsoft update catalogue. https://www.catalog.update.microsoft.com/Search.aspx?q=USB%5CVID_1A86%26PID_7523
Download the .cab file, extract the contents. Using Device Manager update the driver for the partially installed device. After the update TronXY-2 now appears as a COM port.
