I'm using M80 and M81 G-codes to power on/off power supply.
Is there a G-code to know the actual state of the power supply?
  • $\begingroup$ While there is no dedicated command for this, there may be some options. Can you describe your hardware? Are you using a stock printer or a custom? What are you turning off with the M81? Are you just turning off the 12V and leaving 5V board supply on? What boardset are you running? RAMPS? $\endgroup$ May 10 '17 at 19:39
I don't see one at http://reprap.org/wiki/G-code so it's probably safest to set the power supply to the state you want.
Thanks! I confirmed that there isn't such a G-code. I sent a pull request to make this posible: https://github.com/MarlinFirmware/Marlin/pull/6671
Now, "M80 S" reports the current state of the power supply.
