I have a solid of revolution defined by two equations, and I want to generate a STL file for printing from the difference of the two equations, revolved around x=0. I can get a good visualization when I query this on Wolfram Alpha, but I cannot figure out how to download an STL of this. I know there is a way to do this via Wolfram's Development Program but I'm not sure how or if that is the best way to do this. Solutions do not have to involve WA.
$\begingroup$ A programmatic CAD like OpenSCAD or implicitcad will do the job. $\endgroup$ – abruski May 16 '17 at 6:37
2$\begingroup$ Yes, OpenSCAD is free; you should give it a try. $\endgroup$ – Davo May 16 '17 at 13:24
$\begingroup$ @Davo how can I enter equations into OpenSCAD $\endgroup$ – werdna3232 May 16 '17 at 13:28
1$\begingroup$ Well, I'm not an OpenSCAD guy, but I've seen people work wonders with it. The download includes practice formulas and tutorials, if memory serves. $\endgroup$ – Davo May 16 '17 at 13:34
The Wolfram Alpha "Data Download" feature supports STL format, but is only enabled with a Pro Account.
When I click your link to Wolfram, I see the visualization of your equations at the bottom of the page; when I hover over the image, several buttons show below it. One of them is "Data", with a download icon. This gives a number of download options. The File Format drop down includes "STL".
$\begingroup$ I don't have my printing software with me, so I haven't verified that the STL file will be usable... $\endgroup$ – mbmcavoy May 16 '17 at 16:19
$\begingroup$ Is there a way to get this without a pro account? (Or could you share the STL with me?) $\endgroup$ – werdna3232 May 16 '17 at 21:27
$\begingroup$ I don't have an account at all. I'm not signed in, I just clicked your link. I'll see if I can add screenshots to my answer. $\endgroup$ – mbmcavoy May 16 '17 at 21:42
$\begingroup$ Ah - I see the actual download is disabled without having a Pro account. I will revise my answer. $\endgroup$ – mbmcavoy May 16 '17 at 21:46
The best free solution I could find was to graph this (in Desmos), screenshot it, and convert it into a SVG, convert that into an OpenSCAD file, and then use that to make the STL. A similar process is shown on someone's blog here.
