I'm trying to connect two 3D printed parts (ABS) together with a threaded connection. Thus, I need to fix a threaded metal nut (M4) inside a corresponding slot which I've implemented in the design.
Right now I apply a conventional super glue on the nut and press it inside the print, wait for a couple of hours and then use it.
Problem is that the nut keeps falling out of the print when I apply a more tension to the bolt. Can you please advise me on how to make this method work. Maybe some of you aware of special glue for that purposes?
