I have a Monoprice architect which is a barebones clone of the FlashForge Creator Pro, or Replicator 1 Dual. I have upgraded the power supply and added a heated bed and, after getting fed up with MakerBot software, I've started using Cura to slice then post process with GPX.
I did a lot of searching and finally found someone who posted their start and end G-code for this particular printer. The only catch is that his code only works on version 15.04.
Don't get me wrong, 15.04 is a huge upgrade compared to MakerWare. But, I would really like to start using a newer version like 2.5 or anything relatively new.
Here is the start code I found. I have tried it in 2.5 with error in post processing. Any help is appreciated!!
; -- START GCODE --
M136 ; start build
M73 P0
G90 ; absolute coordinates
; set temperatures and assert Vref
M140 S{print_bed_temperature}
M104 S{print_temperature} T0
G130 X118 Y118 A118 B118 ; set stepper motor Vref to defaults
; let the Z stepper vref stay at eeprom level (probably 40)
; home and recall eeprom home position
T0 ; home on the right nozzle
G28 X Y Z ; home all axes at homing speed
G92 X0 Y0 Z0 A0 B0 ; set all coords to 0 for now
G1 Z5 F500 ; move Z 5mm away so we can carefully hit the limit switch
G161 Z F100 ; home Z slowly
M132 X Y Z ; recall stored home offsets for XYZ axes
; wait for heat up
G1 X110 Y-72 Z30 F3300 ; move to waiting position
M116 ; wait for temps
; purge and wipe
G92 E0 ; set current extruder position as 0 so that E15 below makes sense
G1 X110 Y-70 Z0.2 F2400.0 ; move to just on the bed
G1 X110 Y70 E15 F1200.000 ; extrude a line of filament along the right edge of the bed
G92 E0 ; set E to 0 again because the slicer's next extrusion is relative to this 0
; Sliced at: {day} {date} {time}
; Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
; Print time: {print_time}
; Filament used: {filament_amount}m {filament_weight}g
; Filament cost: {filament_cost}
; -- end of START GCODE --
