I have some older resin that got a bit thick. I was thinking I could use some paint thinner to thin it a bit and restore it. My thoughts are the paint thinner is made of terpene oils so should be compatible with the resin.
To test, I went ahead and mixed a half capful of paint thinner with about a cup of resin. I mixed it thoroughly and it seemed to mix well and restored proper viscosity. I then filtered it through a paper coffee filter twice. The results were very nice and smooth resin. I did a UV hardening test with a few drops on a strip and into the UV lamp. It still hardens.
Any thoughts, suggestions or OMGs! before I try this in my printer? It's a Pegasus Touch SLA.
