Cura is generating temperature commands in the wrong order. I need to swap lines 6 and 7 below so that both the printhead and bed can begin to heat at the same time.
Is this code generation configurable in Cura?
5 ;Generated with Cura_SteamEngine 2.5.0
6 M190 S60 ; set bed and block
7 M104 S215 ; set printhead, don't block
8 M109 S215 ; set printhead, block
