On my Mac I've got two versions of Cura installed, in /Applications/Cura250
and /Applications/Cura262
How can I copy my printer and profile settings from Cura 2.5 to Cura 2.6?
Sign up to join this communityOn my Mac I've got two versions of Cura installed, in /Applications/Cura250
Hope this is all you need.
From the release notes page
Cura 2.6 - June 20, 2017 Local version folders. When installing a new version of Cura, a new local directory will be created to make it easy to access old configuration folders and return to old settings if necessary.
So if you know where your current 2.5 config directory is, you should be all set.
From the Ultimaker Forum:
