Is it possible to use Cura Engine (the command line tool) to generate a gcode with support?
Here is what I do now:
CuraEngine slice -j /usr/share/cura/resources/definitions/ultimaker2.def.json -l my.stl -o my.gcode
I found this in the fdrmprinter.def.json which you could might make a copy of and use instead for the -j option:
"support":
        "label": "Support",
        "type": "category",
        "icon": "category_support",
        "description": "Support",
        "children":
            "support_enable":
                "label": "Enable Support",
                "description": "Enable support structures. These structures support$
                "type": "bool",
                "default_value": false,
                "settable_per_mesh": true,
                "settable_per_extruder": false
Change the "default_value" under "support_enable" to true and that could work.
