I am building a Prusa i3 MK2 Clone and I am caught on this one. I have replaced the extruder with a MK8 adapted by myself to fit with most of the previous hardware from the E3D style extruder.
Here's the extruder conversion setup
My current problem is that the nozzle appears to be dragging on the top of the layers. I can't tell if it's over extrusion or a layer height issue or what. I am testing by printing the 20mm calibration cube. The dimensions appear to be spot-on, but the layers start building up too much filament such that it just gets re-melted and shuffled around:
just dragging lines through the print
Anyone have a clue what this could be? Software, Hardware, Slic3r Settings?
I have: 0.5mm Nozzle Diameter. MK8 Direct Drive extruder.
Anything else you want to know?
Thanks!
--- UPDATE ---
Thanks everyone for your help. Turns out it was seriously over-extruding, like 3x what it should have been! I ran through this instructable: http://www.instructables.com/id/How-to-calibrate-the-Extruder-on-your-3d-Printer/ Which helped me with what I needed to do to fix the issue, but just re-flashed Marlin on the printer with the updated setting.
Here's the result! WAY better, I still have some z-wobbling issues but i think the frame just needs more support than it has now and that should fix up the slightly jagged corners.
Steps per mm updated
    $\begingroup$ All of the above :-) . It does look like either too much material or too hot. The former could be a mismatch between physical nozzle diameter and the software setting, or the feed-rate setting. Another possiblity is that the Z-drive software is set for the wrong threads/inch of your hardware, leading to the wrong physical movement for each layer move. $\endgroup$ Oct 18, 2017 at 13:29
You stated your print of a 20mm cube came out spot on so I will rule out any z-axis configuration issues. It clearly seems like you are extruding too much plastic.
I use slic3r myself with repetier so I am familiar with the settings.
Print Settings - Advanced
All the values should be 0 except first layer sometimes is 100%-200% depending on your personal setup. Increasing these values may cause more filament to leave the extruder.
Filament Settings - Diameter
This should be set to 1.75 or 3 depending on your filament size. If you accidentally have it set to 1.75 when your filament is 3mm, it would probably be over-extruding since it pushing almost double the plastic with the same length.
Filament Settings - Extrusion multiplier
This should be set to 1 or slowly adjust it 0.05 increments to reduce overall amount of plastic leaving the nozzle.
Printer Settings - Nozzle diameter
This should be set to 0.5 since your nozzle is 0.5mm. Make sure your nozzle truly is this value.
EDITED 10/19/17 - OP has solved problem and his own answer made me realize I made mistake on how to measure and correct extrusion steps/mm. Ignore this below and see what OP wrote in their edit.
If all these Slic3r configurations fail or are correct and do not solve your problem, I think you may want to look into your motor step settings for the extruder. It may be too high pushing more filament than it should. To correct this, you need to do the length test where you will extrude 10mm or 50mm and measure the string of plastic. There might be some stretch so a 10mm may measure as 11mm but as long as your close it should be good. If you extrude 10mm and you measure 25mm, you need to recalculate your steps per mm.
Also for your first layer, make sure it is not being smushed to the build plate. You want it to be flattened a little to provide good adhesion but not too close to the build plate where it would constrict the nozzle.
Hope this helps, and good luck on your prints. May you never have to deal with thermal runaway error :)
  • $\begingroup$ Minor nit: as to your first-layer comment, so long as filament is being extruded, I've never seen a problem with the final print regardless of how much "smushing" is taking place. $\endgroup$ Oct 19, 2017 at 12:17
    $\begingroup$ @CarlWitthoft Yes, but for parts that are supposed to be fit together and sometimes the tolerance is a little tight, the smushed first layer would overall increase the width of the object(only on the first layer) which may cause it to not fit easily with the second object whose width has also probably been slightly increased. I use a xacto knife to cut this off if I ever get it, but I've learned finding the right height almost eliminates it while risking poor bed adhesion. $\endgroup$ Oct 19, 2017 at 15:05
  • $\begingroup$ good points. Maybe add a brim while keeping that ideal first layer height? $\endgroup$ Oct 19, 2017 at 15:47
  • $\begingroup$ @CarlWitthoft Yes and No, Brim is perfect for adhesion but also is annoying to cut off. I personally use hair spray on my glass bed and I never have to worry about prints breaking off the bed while achieving my perfect initial layer height. The OP clearly uses blue painters tape which I used to use on my prusa i3. From experience more surface area and smushed layer adheres better to painters tape since it has such a bumpy rough surface but because of this I struggled with any fit together prints. $\endgroup$ Oct 19, 2017 at 16:52
  • $\begingroup$ It ends up where the over-extrusion builds up on the nozzle and keeps itself molten, and travels around with the nozzle as it moves. The extra filament on top gets re-melted and moved around as the print progresses normally. You end up with an ok print that has a huge blob left on top at the end. $\endgroup$ Oct 19, 2017 at 18:16
