New to this domain, I got my prusa i3 last week and finished assemblage. Repetier params in Linux Mint 18 are ok too.
I'm now trying to launch slic3r for the first time but I got this error launching config button in repetier :
23:40:37.298 : Can't locate Boost/Geometry/Utils.pm in @INC (you may need to install the Boost::Geometry::Utils module) (@INC contains: /home/mobidi/Téléchargements/RepetierHost/Slic3r/lib /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.22.1 /usr/local/share/perl/5.22.1 /usr/lib/x86_64-linux-gnu/perl5/5.22 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.22 /usr/share/perl/5.22 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base .) at /home/mobidi/Téléchargements/RepetierHost/Slic3r/lib/Slic3r.pm line 32.
23:40:37.298 : BEGIN failed--compilation aborted at /home/mobidi/Téléchargements/RepetierHost/Slic3r/lib/Slic3r.pm line 32.
23:40:37.298 : Compilation failed in require at /home/mobidi/Téléchargements/RepetierHost/Slic3r/slic3r.pl line 13.
23:40:37.298 : BEGIN failed--compilation aborted at /home/mobidi/Téléchargements/RepetierHost/Slic3r/slic3r.pl line 13.
Lines incriminated :
slic3r.pl line 13 :
use Slic3r;
Slic3r.pm line 32 :
Use Boost::Geometry::Utils 0.12;
I tried to reinstall with this tuto : https://blog.lkiefer.org/index.php?article12/installer-slic3r-sous-ubuntu-16-04-et-linux-mint-18 But I got this error when dealing with the first command :
Err:1 **********/ondrej/php/ubuntu xenial/main i386 libpcre3 i386 2:8.39-1+deb.sury.org~xenial+1 404 Not Found
Err:2 **********/ondrej/php/ubuntu xenial/main amd64 libpcre3 amd64 2:8.39-1+deb.sury.org~xenial+1 404 Not Found
Err:3 **********/ubuntu xenial-security/main amd64 libc6-dbg amd64 2.23-0ubuntu7 404 Not Found [IP : 2001:67c:1562::19 80]
And a lot more almost indentical.
I don't know at all how to deal with this I'm not sure if I'm doing the right thing at all, if somebody could guide me throught that I would be very thanksful.
