Could I 3D model and print a working airbrush in PLA?
  • $\begingroup$ Im not sure but there might be a .STL for one of those hand airbrushes, where you blow into it with a paint bowl on to wich pushes out the paint. Not sure if this would be an ideal solution but its an option. $\endgroup$ – Granny Oct 23 '17 at 7:55
  • $\begingroup$ Dear Dylan Rollins Garfield, welcome to our 3D Printing SE site. Please be so kind to review our tour to make sure that your questions willl lead to answers that are beneficial for a wider group of people. What are your idead and where are your problems? From there we can take it to a fruitful discussion 3dprinting.stackexchange.com/tour $\endgroup$ – kamuro Oct 26 '17 at 22:37
The problem with this I see is that the PLA takes and holds paint super well. I have painted it with acrylic a lot and it works great for models you want painted after printing.
I know next to nothing about airbrushing, but it seems to me like keeping a printed airbrush clean for re-use would be a big pain. It looks like they make the pro airbrushes with some kind of stainless steel most likely for the non-sticking purposes of re-use, which PLA just won't have.
That being said, don't be afraid to model it and try! I would make a suggestion that you switch to ABS and then do a vapor bath on the result to smooth out the material and possibly make it easier to clean excess paint out of.
