On my Anet A8 3 printer, running Skynet. When I do not use the G29
command, Auto Bed Level, the printer won't print and just extrudes plastic in mid-air. But when I do use the G29
command it will home and start to print but no plastic will come out. The extruder motor and the connector both work. Does anyone know what the problem might be?
Here is the start G-code I use:
G28 X0 Y0
G28 Z0
G29
M190 S50 ;set bed temp (wait)
M109 S200 ;set head temp (wait)
; Layer #0
G21 ; mm
G90 ; abs
G92 E0 ; reset extr
M106 S0
;segType:Skirt
G0 F4800 E-1.0000
G0 F300 Z0.200
G0 X110.546 Y71.485 F9000
G0 F4800 E0.0000
