My Y-axis on my Monoprice maker select running ramps 1.4 and Marlin makes a thud noise when moving every now and then. I have noticed a 1 to 2 mm shift in the print when this occurs. I tighten the belts and alas no joy. I ordered new bearings which should be coming Monday. I also tried slowing the print down and still get the same result. Anyone have any ideas.
A thudding noise is usually a belt slipping through its end-restraints. A clicking noise is usually a stepper motor missing a step. Seized bearings could be the cause.
The issue was the X-axis top smooth rod came out. this caused the extruder to bang around and shift on the Y-axis when it shifted forward. thank everyone for their help.
$\begingroup$ Thanks for providing the actual solution. It would be helpful if you accepted your (own) answer (it is OK to do this). $\endgroup$– MickNov 13, 2017 at 8:47
$\begingroup$ yes, you cant accept your own answer right away you need to wait 24 hours 😁😁 $\endgroup$ Nov 13, 2017 at 12:15
