I use the Cura; nylon default(recommended) settings for PETG. Upon my filament's box is written 200-240 for nozzle and 75-85 for bed. So I tried 245/80 - 220/80 - 220/60 - 245/60.
But I got same result as you can see in the pics:
My printer is PrusaI3 (actually a chinese kit that I assembled it myself). Also I had good print results with PLA before this. I was using 190/50 for PLA).
  • $\begingroup$ Good question. I see signs of uneven extrusion (blobbiness), or perhaps bad bed adhesion, but it is hard to tell from the pictures. Is there one full, even layer (I see a nice smooth coloration around the print)? $\endgroup$
    – cmm
    Nov 13 '17 at 3:05
  • $\begingroup$ @cmm: the support layers are very nice and smooth but the problem is about center layers. I will change the Teflon today and hope it will solve. $\endgroup$
    – WDR
    Nov 13 '17 at 5:17
  • $\begingroup$ Have you had this result more than once, or only this one time? @Mick answer is pretty likely if this is the first and only time. If you've reproduced this more than once, the problem could be elsewhere. Do you have a direct-drive extruder or Bowden? If direct drive, you might be heating the drive wheel so that the grip is not strong enough. $\endgroup$
    – cmm
    Nov 14 '17 at 2:21
It looks like you have a clogged nozzle/hot end. I use 225°C @ 40mm/s for PETG with 235°C @ 30mm/s for the first layer.
If you print at 245°C, you risk burning the PTFE liner in your hot end. You really need an all-metal hot end to print at such temperatures.
It is possible that you have already damaged the PTFE liner, and this may be the cause of your problem. However, I would check for a clogged nozzle first.
