I have a Prusa i3 printer with mk8 extruder. I am using PETG with (200-240/75-85) degrees recommended temp on it's box. but when I do printing i hear some knocking sound that means there is a problem in extrusion. last time I did increase my temp up to 270 degrees!! maybe this sound solved! but it damaged my extruder's screw's inner Teflon and I forced to change it!
Now I have a new nozzle and extruder's screw, but again I can hear this sound during the printing! I thought maybe it's because of very close distance between the nozzle and the bed, but when I increase the distance, the filament starts to warping!
My nozzle is new and it can't be for clogging. so I decreased the print speed from it's default 60mm(in Cura software) to 50, but didn't solve this sound. Also when I use pronterface and do extrusion manually, it works nice with 200 degrees! but I can hear the sound in 190 degrees. But when I do printing I hear the sound even in 200 degrees! Is this mean I must increase the temperature for printing? how much?
By knocking sound I mean the sound you can hear when you have a clogged nozzle and the extruder's stepper motor can't push the filament into it and rotates with knocking sound!
The extruder motor may be skipping steps because of insufficient current. Typically, the stepper driver will have a small potentiometer that lets you increase or decrease the current. Increasing the current will give the motor more torque/force, but also cause it (and the driver) to heat up more.
It sounds like your filament is not hot enough to be extruded, which will cause the stepper motor to 'skip' (and produce a knocking or clicking sound). 200°C sounds rather low for PETG, and I do not get good extrusion below 215°C. I normally print at 225°C, with the first layer at 235°C. I also print slower than I do for PLA -- 40mm/s and 30mm/s for the first layer.
Note that thermistors can be inaccurate, and may report temperatures several degrees lower or higher than are actually being achieved.
