I'm fairly new to 3D printing but I'm getting the steam up and I chug out pieces without much hassle. One thing though is that I have the impression that sometimes, parts are easily broken, and I suspect bad adhesion between layers.
I'm printing eSun PLA at 208 °C (212 °C first layer), bed at 50 °C first layer then 30 °C.
When I print the Benchy boat, it feels extremely sturdy (even the small chimney is unbreakable by hand), but if I make, say, a 50 mm diameter cylinder with 4 mm wall thickness, It breaks fairly easy along some layer. I don't see any specific error, it "looks" okay.
So my question is:
How do you assure that you print layers that bond enough?
[Edit] I already know that might actually cause bad bonding (low heat, underextrusion, ...) but I'm looking for a way to see when it happens.
Here is an image from when I stopped mid print (you can see the little ooze string just at the start at the crack) for checking dimensions. The next layer didn't bond well because, I guess, the already printed part had cooled down when I un-paused the print (say 1 minute later) or maybe the z-axis went off a bit when I touched the build plate.
Is the only way of knowing layers bonded correctly, to try to break the part apart?
