I am modelling a few cut templates to be used on an hexagonal grid (honeycomb) material using OpenSCAD. Basically, from a reference cell, I need to select all cells that are within a given range and given angle.
I implemented this by creating an in memory grid that covers an area larger than what I need (extra range, 360 degrees), and then testing each cell for both the distance and angle requirements, extruding only those that test positive for both conditions.
Everything works as expected...
...but now I would also like to add the possibility to have the outer contour of the template without having each individual cell within it (so, a single thin line going around the whole "pizza slice" above).
I'm pretty new to OpenSCAD: what would be the best approach here? (I'm happy even with a solution that requires to re-implement what done until now).
hull()
function (if that is what you were going for), and it does not do what I want, as it doesn't contour my shape, it "wraps" it by making a straight line between the most protruding points of each side of it... $\endgroup$ – mac Nov 27 '17 at 21:35
