I'm doing a project for college connecting an app made with app inventor to a Raspberry Pi and then using the RPi to make a printing queue for a Prusa P3 Steel.
The thing is that I already have the comm between the app and the RPi but I need to connect the RPi to the Arduino via USB and select the G-code files that are in the SD card of the Prusa to print. I don't know where should I put the function in the Marlin code or how to manage the serial port read function.
Any ideas?
  • $\begingroup$ why don't you connect the prusa via USB to the Rpi? That way you can feed the G-code directly and keep the queue on the Pi. $\endgroup$
    – Hacky
    Dec 27, 2017 at 13:30
  • $\begingroup$ Just out of interest: Are you using MIT App Inventor for iOS or App Inventor for Android? $\endgroup$
    Oct 9, 2018 at 17:49
You can send the G Codes to select and print a file over the serial connection.
  • List the files
    M20
  • Select a file name
    M23 filename.gco
  • Start/Resue the print
    M24
See https://reprap.org/wiki/G-code for more information M20 through M39 are the ones for interfacing with SD Card files.
