Since i updated Cura from 2.7. to 3.1. I have a really hard time at configuration and especially removing the support interfaces. The update automatically uses the settings from the old version, but as I said: it doesn't work anymore.
I even tried to create a test print with 4 copies of a test object with different settings, but there where no differences in the slicing for them. Every copy and the support interface that belongs to it was the same.
Did anybody have an idea?
Printer Anet A8 with PLA
  • $\begingroup$ I see you are a new user around here, so I hope you don't mind if I bring to your attention that you should upvote any answer that helped you along the way, eventually accepting the one that was closer to solve your problem or - in case none of the answers made it for you - write your own answer and accept it (so that others will be able to benefit from it when searching). :) $\endgroup$
    – mac
    Jan 24, 2018 at 23:46
  • $\begingroup$ unfortunately I got not the time to try any of the points :( give me some time and I will answer you, so also others can profit from the results. $\endgroup$
    – Horitsu
    Jan 25, 2018 at 16:26
  • $\begingroup$ I found the problem: The Support Z Distance only changes the Support Bottom Distance and NOT the Support Top Distance. By activating the two sub-options you can configure this again. I will write a bug ticket. $\endgroup$
    – Horitsu
    Feb 24, 2018 at 9:10
In Cura 3.1 to 3.2.1 (date today is 2018-Feb-24): The Support Z Distance only changes the Support Bottom Distance and NOT the Support Top Distance. By activating the two sub-options you can configure this again.
