I am still at calibration stage and need some info from the PCB. I connected the USB and ran Repetier. The PCB wants to talk at a higher baud rate than my serial port says it can do. I tried setting the serial port to its highest setting 125k and reduced the PCB baud in Repetier setting to 125k. No joy. PC port reverts to 9600 every time I check it. Thoughts?
PC running Windows 7 Home Premium 32bit.
Sorted. Repetier Server was hijacking my com port. Uninstalled it and Repetier host worked fine. As I have no desire to monitor or control prints remotely I have no use for the server software.
Hope that helps others.
Are you sure that the A8 connects to a PC using a serial port? I don't know of any 3D printers that do that. Typically, 3D printers connect to PCs using a USB connection, and there will be a type-B USB socket on the printer.
However, there will be a USB bridge chip on the printer's controller board that connects the microcontroller to the USB socket. This bridge chip does have a serial port that is used to communicate with the microcontroller. Typically, these serial ports operate at 115,200 bits per second (115.2 kbps), although this may vary. Some USB bridge chips are capable of operating at 250kbps.
Often, the software running on the PC needs to know what speed the serial port on the bridge chip runs at, in order to send data at a suitable rate. Of course, the USB connection is capable of handling data at a much higher rate, but the microcontrollers used in many 3D printers are not capable of handling such speeds.
Note that the USB bridge chip on the printer may appear as a virtual COM port on a PC.
  • $\begingroup$ You do know that a COM port is a serial port, right? (virtual or otherwise) $\endgroup$
    – Onno
    Jan 12 '18 at 10:39
  • $\begingroup$ @Onno I know about virtual serial ports, but a maximum baud rate of 9600? That sounds like a hardware (RS232) port to me (or at least, Windows thinks that it is). $\endgroup$
    – Mick
    Jan 12 '18 at 10:59
  • $\begingroup$ Don't know what happened , didn't change a thing but all of a sudden the pc started to talk to the printer.......weird. Can only think my norton was away to internetland to see if it was OK to talk to this new stranger. Thanks for the answers though. $\endgroup$
    – Plodmore
    Jan 13 '18 at 9:55
  • $\begingroup$ @Mick Some computers detects as COM the arduino using the USB port, Serial ports normally uses COM1. USB ports can be detected as COM2 or more, for example my computer detects COM5, COM8,COM21, depending whicn HUB USB i'm using. The speed connection will depend on the baud rate which the Arduino was programmed sometimes @ 9600 for low processing and higher rates for high computing. $\endgroup$ Jan 24 '18 at 4:39
-2
My A8 just started doing this.
I shut down repetier server, and voila, all is good! Since I will go do OctoPi eventually, I just uninstalled RS.
  • $\begingroup$ Hi, and welcome to SE 3D Printing! Whilst your answer may be technically correct, it is rather terse, and, as such, it has been recommended for deletion, unfortunately. If you could expand it then you may get a more positive response. I would recommend that in addition to reading some highly voted answers to gauge the standard expected, that you take a look at the help section relating to answering questions, in particular How to Answer, and take the tour for more information on how stack exchange works. Thanks :-) $\endgroup$
    Feb 15 '19 at 18:30
