Today I finished building and adjusting a Prusa-Clone printer. The brain is a 32bit board with Smoothieware on in. To run the auto bed leveling routine I installed a 3DTouch (BLTouch clone, sorry low on cash). After many headaches, I got everything working fine and I'm happy with the result. Except for one thing...
When the 3DTouch is probing, it is triggered when the nozzle is about 1 mm from the bed. If I set the probe higher, the nozzle crashes onto the bed. If I set the probe lower, the probe would be on the same level of the nozzle, not so good for print time.
Anyone with similar experience or how to sole it? google doesn't show up much regarding this.
Thanks in advance!
