Brand new to 3D printing and have an Ultimaker Original + using PLA (2.85mm). The nozzle/extruder temperature is 200C and the bed/plate is 60C.
I installed the Cura software on my Windows 10 box. I then head on over to tinkercad.com to make a model of a comb. I then exported my .STL file and loaded it up in Cura. I hit the print button. I waited a bit, but noticed that my print was getting lumps in it. Not crazy drastic lumps, but because the object was small, gaps (between the comb teeth) were being filled... not all of them, just some.
I tried adjusting the flow rate from 100% to 90% and it seemed a little better (not perfect, still filling gaps), but when I dropped it lower, it got worse.
I also tried to lower the print speed from the default of 60mm/s to 50mm/s - no change. (travel speed at 120mm/s)
I tried to adjust the bed height multiple times, trying to make sure that it was 100% flat at 180 degrees.
What is wrong here? Is the printer over extruding? Is the temperature too high? Is the flow rate wrong? Am I missing something else?
Check out my prints:
enter image description here enter image description here enter image description here
I also tried printing something else:
Any help would be really appreciated.
Update
Okay, so thanks to macs answer, I took another look at the nozzle and noticed a massive leak - I actually dismissed this earlier as "glue" - OMG.
Anyways, here is the picture of the leakage:
It's very bad. It leaks down and runs over the nozzle. The nozzle also leaks... Is that normal? All I did was turn the printer on, heat up the nozzle to 200C and it started to leak. I suspect that it should not do this... I'm not ready to change the nozzle just yet - I've no idea which one to buy or even where to buy it from (I'm in the UK), so I'd like to get this one working (if possible).
On another note, I have checked the filament settings - All good. Heat settings all good too:
  • $\begingroup$ Did you lower the temperature? I use 190-195 degrees for PLA and 50 degrees for printing bed. It looks like the object does not stick well to the printing bed. Am I right? $\endgroup$ – Marco Jan 16 '18 at 12:17
  • $\begingroup$ @Marco I didn't try to lower the temperatures, no. However, the object actually sticks very well to the bed... I need to pry it off. $\endgroup$ – pookie Jan 16 '18 at 12:19
  • $\begingroup$ What nozzle diameter? And have you played with the retraction setting? $\endgroup$ – Carl Witthoft Jan 16 '18 at 14:26
  • $\begingroup$ Are you sure your nozzle isn't dripping? $\endgroup$ – Granny Jan 17 '18 at 7:49
It is always difficult to diagnose problems from a set of pictures only, and without the original model to compare it with, but yes, from the pictures it looks like your printer has a severe case of over extrusion, possibly in conjunction with a thermal problem.
The first picture in the set is particularly interesting for a number of reasons:
  • The chequered pattern of the top layer looks like being generated by the nozzle "digging" in the layers below and rising the plastic around it. A well calibrater printer should have a top surface with a very subtle texture instead.
  • The teeth of the comb and the gap between them are inconsistent, as are the shape of the tip of the teeth. This let me think your printer actually doesn't operate consistently, over-extruding in some places a lot more than in others. A pinter should be able to accurately replicate its performance along the full length of the comb instead.
  • The plastic has a different finish and colour in different places. Namely, it looks burnt and glossy where the worse print quality is, white and matte where the problems are not so bad. Both the colour and the finish let me thing the plastic in the dark spots have been heated way over its operational range and/or for too long.
In essence what I think it is happening (mind it: this is just a theory) is that your printer is over-extruding and in addition your hot end may have issues with keeping its own temperature constant and within the designed limit. Other factors that may also play a role could be:
  • Wrong settings in the slicer as for example a nozzle diameter set to 0.5 mm when it really is 0.4 mm instead, or the filament diameter being wrong.
  • Blobs of over-extruded material forming and sticking to the nozzle, where they take too much heat for too long and burn before "falling" in the print and damaging it.
  • Filament that is old/of bad quality and that has impurities in it, or has an inconsistent diameter along its length (thus causing over-extrusion in places, but not in other).
  • A nozzle that is not well fixed to the heating block, thus allowing molten plastic to seep out from the joint and run down on the outside of the nozzle and ultimately on the print itself.
  • A nozzle that got damaged and whose opening is not circular and/or not matching its nominal diameter.
  • The extruder hobbed gear not e"biting" in the filament and thus the filament slipping at times, thus being inconsistent in the quality of material being extruded.
So, here's the the trouble-shooting I would go through at this stage:
  • Check your printer setting in the slicer. Doh! :)
  • Take a close look at how the print works while in operation. Do you see blobs forming and sticking to the nozzle? Plastic seeping out from places it shouldn't? Is the nozzle round and true? In case of doubts, just change the nozzle with a new one (it is a less-than-1€ part anyways), easily outspent by the cost of filament in a failed print.
  • Calibrate you extrusion (and thus your flow-rate) by performing accurate measurements over at least 3 length of filament. Matterhackers has a nice how-to that you can follow for this.
  • Manually check the diameter of your filament (at least 5 measurements at at lest 200 mm distance between them) and adjust the corresponding "filament diameter" setting.
  • Calibrate your temperature by using a test tower. This one has extensive instructions on how to use it in the thing description, plus is customizable directly from thingiverse.
  • Print again your model and see how/if your changes affected the print quality in any way.
If the above fails, you could also try to use another slicer, but it's unlikely the problem is with the software.
UPDATE
I'm not familiar with your printer model, but the updated pictures seems to show the leakage happening between the heat block and the heat break, rather than between nozzle and "whatever". ;)
This can actually be caused by two different problems (or the two of them compounding).
  1. The two parts, which are normally just screwed together have come loose.
  2. If your extruder is not "all metal" (which is normally not the case in most printer), the PTFE tube (the whitish plastic tube the filament slides into) may have dislodged upwards, so instead of being a tight fit in the heat block, it leaves room for the molten filament to seep upwards.
In both cases, a reassembly and thorough clean-up of the head is in order. I would suggest trying to find specific documentation for your printer online, but the general process is:
  • warm up the head to printing temperature. All subsequent steps will have to be done at this temperature (wearing protective gloves is highly recommended)
  • remove the filament
  • remove the PTFE tube
  • remove the nozzle
  • remove the the heating block from the heat break
  • wipe as much the plastic as possible (bit drills work well for the hole in the heat block
  • increase the temp a further 20-30 degrees
  • reassemble everything
  • profit
Please note:
  • the heat break is relatively fragile: be gentle when unscrewing. When removing/attaching the nozzle is worth keeping the heat block in place with a spanner to prevent twisting the heat break
  • if you can't remove the plastic when molted, you can try letting it cool and scrape it
  • it essential that the re-assembly be done while hot. Metal expands with heat, so what feels firm while cold will eventually become loose at high temperature
  • $\begingroup$ Hey, thank you for the detailed response. Your question Plastic seeping out from places it shouldn't? caught my eye - I do indeed see leakage. I took a closer look... turns out it is leaking very badly between the nozzle and the tube/pipe/whatever. I'll add a picture to show. $\endgroup$ – pookie Jan 21 '18 at 11:04
  • $\begingroup$ @pookie - I updated my answer above, let us know how it goes and mind that disassembling the hot end is probably the trickiest maintenance operation to be done on a printer, so don't get discouraged should you find it difficult to perform! Take your time (or find a friend/hackerspace that may show you how it is done). :) $\endgroup$ – mac Jan 21 '18 at 13:08
  • $\begingroup$ Thank you :) I will go through the process of removing, cleaning and reassembling the unit and let you know how I get on. I've read a lot of stories about people snapping the tube... It's my wife's work printer, so what the heck? I've got nothing to lose! :) $\endgroup$ – pookie Jan 21 '18 at 13:33
