At first few layers, each layer has offset to -X/-Y direction base on previous layer. But above ~2mm, it is vertical.
I've checked the printer build that there is no noticeable error in towers. Tried both manual calibration and Marlin auto calibration G33 with z probe.
No idea what's the cause and don't know which part I need to check with.
enter image description hereenter image description here
Finally I found out that it was caused by not enough torque output by B tower stepper motor. Increasing current didn't work. I replaced the stepper motor and it prints perfectly.
  • $\begingroup$ Please "accept" your own answer so it won't show on the un-answered list. (unless you are waiting on a better answer of course. :) ) $\endgroup$ – David Lotts Mar 8 '18 at 19:53
  • $\begingroup$ How did you conclude it was tower B's stepper that was at fault? $\endgroup$ – dibs Feb 6 '19 at 5:48
  • $\begingroup$ @dibs I just put my hand to try to stop the slider. $\endgroup$ – aleung Feb 11 '19 at 4:20
