I am still trying to dial in my Anet A8.
The Marlin firmware takes too long to scroll through the axis settings when I change them, so I use Repetier Host instead issuing M92 followed by M500.
I noticed in the log window that X goes in as typed but that Y has a *75 after the value i input. Can anybody tell me why/what it is for? I suspect I know what it does just no idea why it is doing it.
*75 is the checksum value, (a method for verifying the integrity of the transmitted information).
RepRap wiki gcode : checksum
There is probably an option to not use/disable checksum generation in repetier/slicers, however this may only be advantageous for use with code run from the sdcard as it is extra processing (and probably less relevant when not being transmitted over serial connection. )
| improve this answer | |
  • $\begingroup$ Thanks. Calibration getting closer but not quite right yet. I just wondered if this was a possible source of my X Y problem of circles not being round....grrrr. I will ignore it. $\endgroup$ – Plodmore Feb 7 '18 at 12:42
