As part of a project with my university, I have developed a new extruder to attach to a Prusa i3 MK2. My problem is that both the nozzle and PINDA probe have moved 17mm forward and 0.5mm to the right. As a result when I try and calibrate the printer it moves to the home position and the PINDA probe is too far out over the heatbed so it doesn't detect the printing surface. What is the simplest method of moving the home position so that the printer can be properly calibrated?
UPDATE: I am planning on removing the heatbed and placing spacers that will move the printing surface 17mm forward. This should then prevent the printer losing any printing area and hopefully prevents me having to edit any code. Can anyone see any problems with this I'm overlooking?
The simplest thing to do would be to move extruder 17mm closer to be the same as the original printer but my deadline is fast approaching and I haven't time for a redesign that large.
