I am trying to use a 3D850 PLA filament which is supposed to work without any issues with any PLA printer. As a printer, I use Dagoma NEVA which is supposed to work with any PLA filament. I can print with the filament without any issue, but I encounter a problem when I need to swap the filament. Somehow 3D850 sticks within the nozzle and even when it's heated I have to push really hard with another filament to push the current filament out (usually when the nozzle is heated up I can just easily push a filament inside for it to come out of the nozzle).
Is there any special behavior of 3D850 that may cause it to stick inside of the nozzle?
