I bought a new printer, and unfortunately the left nut for the lead screw isn't tapped.
Does anyone know the thread size, w.r.t. both pitch and lead, of the lead screws?
Sign up to join this communityI bought a new printer, and unfortunately the left nut for the lead screw isn't tapped.
I have the Anet A8, I confirm the threads are Tr8x8(p2). This is explained as "Tr" for trapezoidal thread followed by the nominal diameter in mm. The digits after the "x" denotes the lead of the screw (how much does the nut advance per revolution). The value between the brackets "p2" denotes the pitch. This means that the screw has 8 (lead) / 2 (pitch) = 4 starts.
More information on threads is found on Wikipedia.
I don't own the printer, but the intertubes identify it as a "TR8X8 T" (8mm diameter / 8mm offset per revolution).
The pitch no matter the screw is the distance between the threads. The lead can be different based on a one or two start threads.
