I'm thinking about building a Cray-2 inspired cluster. I'm concerned about the exterior housing modules, proportions and panels.
Has anyone done a good 3D scan of one?
  • $\begingroup$ I believe that, with the last changes, the question has more objective answers and, while not one of the topics described in 3dprinting.stackexchange.com/help/on-topic, it doesn't fall into the "bad question" criteria either. $\endgroup$
    – rbanffy
    Apr 19 '18 at 11:14
  • $\begingroup$ you did nothing to change the scope or target of the question rbanffy: Your question is "Where to find a model of X", which is not Troubleshooting, Repair, Best Practice, Technology, Material, Capabilities, how to design your OWN parts or something about print services. It stays off topic. $\endgroup$
    Apr 19 '18 at 15:22
  • $\begingroup$ "The following topics are merely suggestions, topics are not necessarily limited to the following and all topics are subject to community discretion" (from 3dprinting.stackexchange.com/help/on-topic) $\endgroup$
    – rbanffy
    Apr 20 '18 at 10:01
LMGTFY, etc. etc. Depends on the amount of detail you want. A cheap starter: here, or here or irrational fruit
