12
So I bought a Lulzbot Mini a couple months ago and finally downloaded Ultimaker's version of Cura... Boy... have I been missing out...
One feature Ultimaker Cura implemented that I've been looking for is a "pause at z-height" feature ("post-processing tool"). I'm building prototypes of an electronics device, and creating two pieces that snap together looks a lot worse than printing a single piece. If I could pause my print, insert my electronics, and continue printing, my device would look a lot more professional (even if it took longer to make).
My one concern is the lithium ion battery. Right now I'm printing in TPU. With a heated bed of 40 degrees Celsius, and a heated extruder at 240 degrees Celsius, there seems to be a significant risk that the lithium ion battery reaches a temperature above 60 degrees Celsius (damaging the cell, causing a potential explosion). Granted, I am not sure what "60 degrees Celsius" actually means. It could mean only one part of the packaging needs to reach this temperature, or it could mean the entire LiPo's internal temperature would need to reach this. In either case, the numbers don't look good.
On the other hand, the heated bed surely doesn't need to remain heated beyond the first few layers? Additionally, I can create a "roof" for the LiIon battery that I can slip it under, providing some insulative TPU before the rest of the device. I think the print would happen safely like this, but obviously, an explosion would be really really bad. Like it would probably burn my house down, and I would be asleep when it happened.
Does anyone have any experience doing this? Is there a way to turn off the heated bed mid-print? I guess I can insert a g-code line during the pause? Will this affect the remainder of the print you think? Am I being paranoid? Can the extruder actually pass heat through a 1–2 mm of insulation and cause an explosion? Anyone know how heat travels from the initial, liquid print material through the rest of the structure?
Any more advice or things I should consider before pursuing this?
A more specific pause type might be helpful, if anyone knows of any.
    $\begingroup$ Is wrapping the battery into something heat dissipating an option? Usually putting a battery next to a heater is a big no-no. You don't want to be close when it goes wrong, neither does your house. $\endgroup$
    – Mast
    Apr 25, 2018 at 4:36
    $\begingroup$ I'm not sure why you'd embed the battery like this either. It sounds like your construction will make it non-removable. $\endgroup$
    – Mast
    Apr 25, 2018 at 4:37
  • 5
    $\begingroup$ @Mast Because no electronics manufacturer does that. $\endgroup$ Apr 25, 2018 at 9:58
    $\begingroup$ One further drawback to this method of printed your part is that you are only able to produce the part when you have internal components on hand. If you design the part so that it can be printed without the internal components you can have parts created even without the internal components and perhaps improve speed of creation of additional "devices" by having a supply of this part that you just draw from. $\endgroup$ Apr 26, 2018 at 13:26
    $\begingroup$ I'm going to note that if you choose to go this route, look into how to put out battery fires. I believe water will just make it worse.. $\endgroup$
    – StarWind0
    May 23, 2018 at 16:16
6 Answers 6
9
There is an option to directly insert extra commands at a specific Z height, no need to enter them manually.
That said, it is a bad idea to turn off the heated bed while printing, because this will often detach the object from the bed completely (that's kind of the point of having the heated bed in the first place: better adhesion while printing, and easier removal afterwards).
I wouldn't print over a battery to enclose it, not just because it is likely to damage the battery, but also to keep the battery exchangeable. Enclosing the rest of the design in a case is possible, but normally it is easier to print two separate parts that can be screwed together through a hole in the PCB.
So, experience: it's not worth it usually.
9
I would have to see your design to comment more but why not just change your model with the lid or top that can be either fused on later or attached in some other fashion?
It is possible to turn off the heated bed after a certain layer. It looks like there is a discussion here with the G-code: Can Cura Turn Off a Heated Bed Partway Into a Print?
I would personally avoid exposing the battery to the heat generated by the hotend or the build plate. Printers alone can burn your house down. Why combine it with the awesome power of a lithium ion battery?
    $\begingroup$ The first sentence of your answer should be a comment on the original question (though the question itself already partially addresses it). You are linking to a discussion on turning the heated bed off, but we prefer to have self-contained answers. Could you summarize the main points of the linked discussion here? $\endgroup$ Apr 25, 2018 at 8:10
If your heatbed is at 40°C, and it's not dangerous until 60°C, I wouldn't worry.
The heatbed is what heats up the printed object, not the print head. It will obviously heat it up a tiny bit in a small local area when printing, but the heat dissipates rapidly, only affecting the temperature of the object very little.
If you're worried, try getting a laser thermometer, and monitor the surface temperature of the battery during a test print. They're like $10, so it's not a big investment to try it out.
Alternately, maybe you can do a test print with a stand-in for the battery, and embed a temperature probe in the stand-in, and monitor the temperature real-time while printing.
  • $\begingroup$ Laser thermometer is a great idea. $\endgroup$
    – K Mmmm
    Apr 25, 2018 at 17:11
  • $\begingroup$ I've personally had bad luck with laser thermometers. I'd also look at those Flir thermal cameras, at least recordings of. Get some idea how it works. $\endgroup$
    – StarWind0
    May 23, 2018 at 16:15
  • $\begingroup$ Could you elaborate on how you've had bad luck with laser thermometers? So far when I've used them, they've always worked as expected. They do require some area available to measure, can't measure something as small as a few millimeters, you need at least a few square centimeters, but a battery like this will have a surface area large enough to measure. $\endgroup$
    – Gertsen
    May 25, 2018 at 6:48
Although the bed may only reach 60°, the extrusion above the battery will be at closer to 200°C. Granted there will be a fairly low heat flux, but it will still cause ageing of the battery. At a minimum, some insulation or packing above the battery would seem like a sensible move. This could be printed material, and you could print over the top if you really want to seal the part.
Also remember that as LiPo cells age, they generate gas (this is designed to be trapped in the pouch) and swell. You should try and avoid any risk of puncture if this happens.
Well. First. If you ever think, hmm this might cause an explosion. DON'T DO IT. SERIOUSLY. Modify the design so you can insert the battery.
That said, most softwares will let you set a heater temp per layer. I have mine set through simplify 3d. I usually use this setting for the hot end, as I like to have the first layer hot. You will have bad results doing this with the bed as you will likely cause the print to expand or shrink enough to pop off. You are better not using the heated bed for the print than to turn it off. Look into rafts as well. That is how makerbot helps mitigate their heatless beds. A fan will also help..
AGAIN do not try anything that can possibly might blow something up. There are a lot of variables you do not know, such as how conductive the plastic is and how much will travel through the hotend to the battery. Or how off the specs are for this battery.
  • $\begingroup$ If you just Google-search videos of lithium batteries exploding, they don't go bang, they go fwoosh. Do the experiment outdoors in a non-flammable surface surrounded by non-flammable things and have a fire extinguisher on hand, and you should be okay. Some chance of damaging your printer. I am not OSHA and this is not safety advice. $\endgroup$
    – user253751
    Jul 18, 2021 at 20:53
-2
Discharge the battery entirely, then there is no danger of ignition if the membrane breaks. The battery cells are usually protected by Kapton tape (LiPo) or maybe even metal (LiIon). Both will withstand the temperature of 240°C. The downside is that the cells are damaged after a deep discharge. You should discard the battery afterwards.
What I would expect when you do that:
A deeply discharged battery will bloat up because the solvents will gas out. This will also happen if you heat up the battery enough (>>60 degree). The gases themselves can be ignited again but are captured in our air sealed Kapton envelope :) Igniting these gases will be comparable to a short flash with a spray can.
The temperature is not enough to damage the envelope. The solvents will be also not very dangerous in that temperature range. In case of mechanical breakdown of the membrane nothing will happen anymore.
From Solvents and Additives:
    $\begingroup$ Could you provide any references that you can link to which would back up your claim? Not only, as you say, would the LiPo be (probably irrevocably) damaged, but I am also not sure that it would be terribly safe to heat up even a fully discharged LiPo . $\endgroup$
    May 23, 2018 at 15:52
    $\begingroup$ Recharging a fully discharged LiPo is a pretty bad idea too. I've had some of them burst (not explode) after doing that. $\endgroup$
    – K Mmmm
    Oct 15, 2018 at 18:30
  • $\begingroup$ Should be clear, why you write this? $\endgroup$
    – dgrat
    Oct 16, 2018 at 8:47
