I wrote a command in Marlin firmware which changes Neopixel color based on extruder temperature.
In my start G-code for I set the color to white. How to execute my above command from the end G-code so that the the color changes per request?
As your color is based on the temp reading, as far as I know, there is no G-code to read a temperature and push that value to another command. The way you can do it is:
  1. Static color change - use same method as you are setting to white
  2. Intercept firmware temperature reading function and push that value to led module
