Ok so I am trying to print a new fusion 360 file that I converted into an STL and then into gcode using cura and I got the gcode loaded onto the SD card and mounted into my Monoprice 3D printer, Maker Select 3D Printer v2, and tried to do a print. Now here is the strange part. When I choose "print file" and then select a gcode to print it takes me back to the main screen and from there the 3D printers screen displays "Printing...0%" for a few seconds. After this it just goes back to displaying "Stepper Disabled." And if it is not stepper disabled it is just a blank screen. I tried to mount and print multiple gcodes just to make sure that it was not the softwares fault and low and behold I was running into the same issue.
Now before using today all of the gcode was printing just fine, however for some reason today it decided to give me this issue.
