I want to render a visual of an mesh I created with a real support structure that a 3d printer would print. I haven't had any luck in finding a way to do this. Is there a program (ideally free) that can generate the proper support structure and export it into a mesh format, like .stl or .obj ?
  • $\begingroup$ Why do you need export as object or STL? if the gcode has all data to be printed and previewed before printing if desired. $\endgroup$ May 25, 2018 at 3:48
  • $\begingroup$ @FernandoBaltazar I want to render the original object and the support structure in my 3D program. I'm trying to create a graphic that shows a real support structure for an object, and I want to have full control over how I compose the scene. $\endgroup$
    – joegnarly
    May 25, 2018 at 14:57
You could try Meshmixer its free and the supports generated with it are embedded into the 3D model.
Here you can find a reference on Meshmixer supports. Meshmixer is well known for making custom supports for complex 3D models.
