So as the title said my heated bed stopped heating mid print.
I'm pretty confident the bed itself is not the problem as I've ran continuity tests from the wires and a resistance check (which showed a total resistance of about 1.5 ohms, which is where it should be). I've done voltage checks across the input terminals which showed a successful output of 12 V.
Finally I did a voltage test across the output terminal at D8 where the heated bed should be outputted to. The result came up with nearly 0 V. I then noticed that the LED that usually lights up for D8 was turned off. The weird thing is, I unplugged the wires from D8 and this time the LED lit up like it was supposed to. Due to this, I believe the problem to be with the MOSFET attached to D8.
My proposed solution would be to move the heated bed terminal to D9 instead of D8. I wish to this because despite the firmware set up for a fan, I do not have a fan attached to D9. This leaves this terminal open and with a potentially unharmed MOSFET. Despite this I have found no information on how to go about accomplishing this.
What do you guys think? Is that even a good idea or should the component (or board be replaced)? Any help would be greatly appreciated.
