I'm trying to get my printer to auto level its bed, with Marlin firmware using the following:
- Printer: Kossel Linear plus (Delta 3D printer)
- Board: MKS Base V1.5
- Firmware: Marlin customized
I go into the menu on my LCD, and go to the prepare screen. The screen has the following options:
- Auto home
- Level Bed
- Bed leveling: off
When I select the "Auto home" function, the printer uses the stops at the top of the delta to zero itself.
When I select the "Level bed" function, the printer once again uses the end stops to level itself.
If I turn the Bed leveling to ON, then the Level Bed function will do the exact same thing.
My auto-leveling device is connected to the Z-axis end-stop, and looks like so:
I have the #define AUTO_BED_LEVELING_LINEAR
line in my config.h, as well as the #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
line. I'm not sure why the printer doesn't actually lower the head to the plate and press the endstop.
Any clues as to how to make the printer level the bed and not home the XY axis?
