I purchased two DQ542MA drivers in order to run two NEMA 17 steppers. After about five days of use I noticed that the green indicator light had gone out on both drivers.
The DQ542MA driver running my NEMA 23 High Torque stepper was still running and it has been connected to that stepper for five months now. Using an Ohm meter to check I found that the 10amp 125v LittleFuse connected to the power pins had blown on both drivers connected to the NEMA 17 steppers cutting off the power.
I decided to test the still working driver by disconnecting it from the NEMA 23 stepper and corresponding pins on the motherboard and connecting and resetting it to work with one of the NEMA 17 steppers. The minute I turned my printer back on, the still working stepper (now attached to the NEMA 17 stepper) immediately blew the same fuse. I don't understand why the NEMA 17 steppers blew the fuses of the drivers, seeing as how both are properly set to a RMS of 1.69 and a pulse/rev of 400, and both are connected to a 24v PSU.
My question is: "When I fix the drivers should I solder in a 15amp 125v LittleFuse to better help the power flow and prevent any further blown fuses?"
solder back the 10 A 125 V fuse
? Upgrading the current capacity of a fuse in a device designed and built to specific tolerances is generally a very dangerous thing to do (as Professor's answer points out) unless you really know what you are doing... Your comment, whilst well meaning, just seems to be particularly bad, if not hazardous, advice. $\endgroup$ – Greenonline♦ Jun 27 '18 at 0:49
